At the time I did the experiment i did not monitor the current draw. As far as doing the load test on the battery. When i first started the battery was almost completely sulfated. After about 3 weeks of charging and discharging the battery with the 3 fans it reached about half capacity on the load tester. the capacity seems to be getting better with every charge. But the speed of the charge has not increased. I am still charging and discharging the battery at this time.
I am currently experimenting with 12 fans in series and parallel arrangement to increase both voltage and current. I have not reached any conclusions on that as of yet because I am not finished, I just received the additional fans in the mail
The 3 fans themselves had an original capacity of combined 1 and half amp approx. Each drawing .5 amps before the circuit was taken out. I was astonished too, thats why i filmed it. But at the time i was not sure what direction this would lead me so i did not take all scientific measurements.
At this time I am monitoring current draw and voltage on all my endeavors. I was also astonished at the levels the capacitor reached on the discharge, that one i had 6 fans hooked through parallel with 3 of them running and 3 of them running through the coils but not running them selfs. 1 of the 3 that was running would self start, all them had neon glow even tho 3 of the fans were not running. You may be able to see that in the film.
More data is coming in every hour.
