  #20 (permalink)
Old 05-25-2008, 08:04 PM
theremart's Avatar
theremart theremart is offline
Senior Member
Originally Posted by aladinlamp View Post
HI
i have 3 posts
1st have 2 wires
2nd have 2 wires
3rd has no wire
where exactly should i cut them
thanx
Wow yours does not look like mine. yours does not seem to have metal posts.... You will have to come up with a way to separate each wire to a certain post. Perhaps hot melt glue? You might have to get creative on this one.
What i did was to cut one of the wires off the post. Note, before I did so I looked to see which of the wires would be easy to unwrap on of the wires was buried in wire and would not of let me unwrap it.
After I cut the wire, I carefully unwrapped the wire from the coil till it gave me enough wire so I could wrap it back on the coils to the new post. The new post was a resistor wire that I found fit very snug into the hole of the 4th post. I applied heat to the post carefully till it melted it. You might want to try superglue or other means of securing it, but this worked for me. As mentioned before it is very easy to over heat the post.
Then to strip the wire so I could solder it to the post I burnt it with flame again careful not to damage the rest of the wire or coils. This I wrapped a few times to the post. One thing to note is you want to post to be even height with the other posts. I found out the hard way....
Then after all the wires were mounted I then tested with the ohm meter to find which wires went to which coils... If it does not give you an ohm's then it is not connected to the other coils.
I had to work today, but will be putting up a video of my completed results. Maybe tomorrow.
I want to thank you once again for the simple to follow instructions, I have wanted to do this project but was always afraid of the small wires.... Not anymore
Mart
