Hi Jetijs
Thank you for the reply. I have done what you said and have learnt a lot. I guess it is true to say the learning curve is vertical at the moment. I do have a good workshop with milling machine , lathe etc. I also have a new toy which is a plasma cutter. Great for cutting anything metal and quick as well. Very low heat input to the cutting area so I can cut thin plates without distortion. Why has no one made just 1 cell to find out all they can before making a whole set. Is it because of the voltage supply issue of 1.4V at 20 to 50 amps?? It would save a lot of money, thats for sure. I have about 4 nearly new 0 to 50V at 100 amp adjustable power supplies. They can operate in constant current and constant voltage modes. I thought I would start there.
Blowback
