Originally Posted by MoHHO
I am having a tough time trying to figure out how to wire up this relay. Here's a link to the wiring schematic: http://i271.photobucket.com/albums/j...g?t=1210722490
I also want to keep it wired in with my switch. I've already got the thing mounted in my dash, even if I never use it I want it to be functional. So, I've got:
Power wire from the fuel pump fuse
Pos wire from battery
Ground
Load wire (going to positive on booster)
Where do these wires go to the numbers that correspond on the relay?
Please help!
86 to + tap from Fuel Pump Fuse
85 to common ground
30 + from Battery (Use Appropriate Gauge)
87 to Booster +
87a Could run to an LED that would light if something goes wrong and you lose power through relay...
Also 87 and 87a could be backwards not knowing if that schematic is showing with power to the applied coil or when the relay is not powered.
