  #4 (permalink)
Old 05-14-2008, 12:35 AM
Redmeanie's Avatar
Redmeanie Redmeanie is offline
Senior Member
Originally Posted by MoHHO View Post
Holy moly I just went to PepBoys and spend $10 for the same relay that cost $2.40 there! Ohh well, when you add in the shipping it'll be about the same.
I'm an electrician but when it comes to automotive wiring I'm lost. Wouldn't there already be a fuse for the fuel pump? If so, how would I use the spade tap with that? Wire in an inline fuse and tap off of that to the relay?
Im talking about a tap that you pull the fuse out and this "Tap" slides over the fuse blade then you re-insert the fuse. Radio Shack carries them if you want an easy to find source.
