Originally Posted by MoHHO
I have it on a switch and accidentally left it on overnight. This morning my battery was dead (go figure!).
What do I need to do so when I start my truck everything will be ok? Just let it air out for a day or so?
MO
Mo,
First off you need to do away with the switch and go buy you a Relay like this one:
12V SPDT 30 AMP AUTOMOTIVE RELAY | AllElectronics.com
They also sell a Relay socket:
SOCKET FOR AUTOMOTIVE RELAY | AllElectronics.com
Wire the relay by putting a Fuse spade tap into the fuse slot for your fuel pump.
This will make it where it only is on when your key is turned to the run position.
This is the only "Safe" way to wire it.
As far as your booster goes just rinse it clean on the inside and you will be back to normal.
