Old 05-09-2012, 10:36 PM
MonsieurM's Avatar
MonsieurM MonsieurM is offline
Platinum Member
Send a message via MSN to MonsieurM
"Mind (as well as metals and elements) may be transmuted, from state to state; degree to degree; condition to condition; pole to pole; vibration to vibration. True Hermetic Transmutation is a Mental Art."
Gnostic.Org: The Kybalion
"Transmutation" is a term usually employed to designate the ancient art of the transmutation of metals-particularly of base metals into gold. The word "Transmute" means "to change from one nature, form or substance, into another; to transform" (Webster). And accordingly, "Mental Transmutation" means the art of changing and transforming mental states, forms, and conditions, into others. So you may see that Mental Transmutation is the "Art of Mental Chemistry," if you like the term-a form of practical Mystic Psychology.
But this means far more than appears on the surface. Transmutation, Alchemy, or Chemistry, on the Mental Plane is important enough in its effects, to be sure, and if the art stopped there it would still be one of the most important branches of study known to man. But this is only the beginning. Let us see why!
The first of the Seven Hermetic Principles is the Principle of Mentalism, the axiom of which is ''THE ALL is Mind; the Universe is Mental," which means that the Underlying Reality of the Universe is Mind; and the Universe itself is Mental-that is, "existing in the Mind of THE ALL." We shall consider this Principle in succeeding lessons, but let us see the effect of the principle if it be assumed to be true.
If the Universal is Mental in its nature, then Mental Transmutation must be the art of CHANGING THE CONDITIONS OF THE UNIVERSE ( and thus changing your reality , along the lines of Matter, Force and Mind. So you see, therefore, that Mental Transmutation is really the "Magic" of which the ancient writers had so much to say in their mystical works, and about which they gave so few practical instructions. If All be Mental, then the art which enables one to transmute mental conditions must render the Master the controller of material conditions as well as those ordinarily called "mental."
Signs and symbols rule the world, not words nor laws. -Confucius.
