Hi jetijs
I have read all the parts I can about your electrolizer and would like to try and make one. I need a little help as to the final setup you used and I cannot see how you did the connections. What do you know about PWM as to its effect. I have made a 50 Amp PWM unit with either constant current or constant voltage. I guess if you keep the voltage constant then the heating effect will be minimal. I have started at the other end and now need to build the best gas unit I can. In my workshop at work I have most machines and can do the cutting myself. I have a good plasma cutter and will make the electrodes from SS plate. Some one wrote the thinner the better, is that correct?? Waiting to here from you. This is a great deal of fun.
Blowback
Reason: spelling
