  #1653 (permalink)
Old 05-09-2012, 11:23 AM
MonsieurM's Avatar
MonsieurM MonsieurM is offline
Senior Member
Send a message via MSN to MonsieurM
Since we are talking about Nature's building Blocks:
are you familiar with Cellular automaton - Wikipedia, the free encyclopedia
A cellular automaton (pl. cellular automata, abbrev. CA) is a discrete model studied in computability theory, mathematics, physics, complexity science, theoretical biology and microstructure modeling. It consists of a regular grid of cells, each in one of a finite number of states, such as "On" and "Off" (in contrast to a coupled map lattice). The grid can be in any finite number of dimensions. For each cell, a set of cells called its neighborhood (usually including the cell itself) is defined relative to the specified cell. For example, the neighborhood of a cell might be defined as the set of cells a distance of 2 or less from the cell. An initial state (time t=0) is selected by assigning a state for each cell. A new generation is created (advancing t by 1), according to some fixed rule (generally, a mathematical function) that determines the new state of each cell in terms of the current state of the cell and the states of the cells in its neighborhood. For example, the rule might be that the cell is "On" in the next generation if exactly two of the cells in the neighborhood are "On" in the current generation, otherwise the cell is "Off" in the next generation. Typically, the rule for updating the state of cells is the same for each cell and does not change over time, and is applied to the whole grid simultaneously, though exceptions are known.
Cellular automata are also called "cellular spaces", "tessellation automata", "homogeneous structures", "cellular structures", "tessellation structures", and "iterative arrays"
here is the interesting part (highlighted )
Cellular automata are often simulated on a finite grid rather than an infinite one. In two dimensions, the universe would be a rectangle instead of an infinite plane. The obvious problem with finite grids is how to handle the cells on the edges. How they are handled will affect the values of all the cells in the grid. One possible method is to allow the values in those cells to remain constant. Another method is to define neighbourhoods differently for these cells. One could say that they have fewer neighbours, but then one would also have to define new rules for the cells located on the edges. These cells are usually handled with a toroidal arrangement: when one goes off the top, one comes in at the corresponding position on the bottom, and when one goes off the left, one comes in on the right. (This essentially simulates an infinite periodic tiling,
the following will sound familiar (highlighted part ) ... see: The Golden Tractate of Hermes Trismegistus applied to electromagnetism
In 1969, however, German computer pioneer Konrad Zuse published his book Calculating Space, proposing that the physical laws of the universe are discrete by nature, and that the entire universe is the output of a deterministic computation on a giant cellular automaton. This was the first book on what today is called digital physics.
In 2002 Wolfram published a 1280-page text A New Kind of Science, which extensively argues that the discoveries about cellular automata are not isolated facts but are robust and have significance for all disciplines of science. Despite much confusion in the press and academia, the book did not argue for a fundamental theory of physics based on cellular automata, and although it did describe a few specific physical models based on cellular automata, it also provided models based on qualitatively different abstract systems.
[1011.0313] The fractal structure of cellular automata on Abelian groups
Johannes Gütschow, Vincent Nesme, Reinhard F. Werner
(Submitted on 1 Nov 2010)
It is well-known that the spacetime diagrams of some cellular automata have a fractal structure: for instance Pascal's triangle modulo 2 generates a Sierpinski triangle. Explaining the fractal structure of the spacetime diagrams of cellular automata is a much explored topic, but virtually all of the results revolve around a special class of automata, whose typical features include irreversibility, an alphabet with a ring structure, a global evolution that is a ring homomorphism, and a property known as (weakly) p-Fermat. The class of automata that we study in this article has none of these properties. Their cell structure is weaker, as it does not come with a multiplication, and they are far from being p-Fermat, even weakly. However, they do produce fractal spacetime diagrams, and we explain why and how.
Now watch the following vid of a TED Presentation by Stephen Wolfram
and the possibilities offered by this new dimension of Fractal
just a simple observation .... he is wearing a "violet / purple" shirt
Stephen Wolfram: Computing a theory of everything - YouTube
Stephen Wolfram: Official Website
