  #5 (permalink)
Old 05-12-2008, 04:15 AM
sykavy sykavy is offline
Senior Member
Originally Posted by Aaron View Post
Sykavy,
Have you compared it to any of John Bedini's work?
My Work on Rife
Yes I have compared it . It seems to me that John is keeping his hand close to his chest if he understands this, He hints at it with talking about hetrodyning. But he seems to be using a carrier wave with an audio frequency. The harmonic may be right but there might not be enough power from a harmonic to kill a pathogen. Plus what he has in the beginning of his site is really OVER my head. I don't understand what he is talking about, the GATING FREQUENCIES. He is also using something different whith pumped waves etc...
One of the reasons I believe that this new info may be the right way is a quote from Rife:
“I spoke only Friday evening to a Mr. John Chamblin, a radio man now connected with Beam
Rays Inc., about the redesign and building of a device according to the old Rife Ray principles; as the
present instrument has been so deviated away from that old principle that it is nowhere near the
same...those devices which you have are merely working on a harmonic and not a true frequency; and
in our research on electronics, we definitely know that there is no possible way of controlling electrical
harmonics of a frequency.” (Letter from Dr. Rife to Gonin dated May 14, 1939)
Rife seemed to want a true frequency and not just a harmonic. From what I have been reading about mixing frequencies, is you get a plus and minus when you mix two frequencies eg. BX virus : 4,680,000 + 3,076,000 = 7756000
4,680,000 - 3,076,000 = 1,604,000.
It isnt clear if Hoyland or Rife wanted to mix these two frequencies to get these two other frequencies (plus and minus) It could be this mixing is important. Because if it wasn't impotant Rife wouldnt have used two RF generators before Hoyland in his Rife #3 There needs to be experimentation.
What Hoyland did was to mix the two frequencies in the tube.
Another reason is that they just figured out an old Hoyland circuit design that had a second tank coil to produce High RF:
From the trial we learn that Philip Hoyland developed and tested his instrument in the lab. How
could Philip Hoyland have tested it unless he put micro-organisms under the microscope? From the
trial papers we learn that Philip Hoyland didn’t tell Dr. Rife what frequencies he was using in the instruments.
Dr. Rife thought the instruments were using his frequencies (the upper band frequencies) but
with harmonics because this is what Philip Hoyland told him. We read earlier that Dr. Rife eventually
found out about the changes Philip Hoyland made and was very unhappy because he believed that the
instruments were not working on his frequencies or principles.
The information that we now have
shows that Philip Hoyland’s instrument was working on Dr. Rife’s principles and on his frequencies but
in a different manner than Dr. Rife was used to using. This is the reason that the instrument worked so
well. Philip Hoyland was still using Dr. Rife’s principle of coordinative resonance but hid the truth from
Dr. Rife.
We will now look at the new information starting on the next page
I told him that we did not need to do the test with solid state frequency generators
because I had conducted a similar test back when John Bedini and I were working on the AZ-58 tests.
John Bedini and I knew that the original Beam Rays instrument was a lot more powerful than the AZ-58
because of the Rife documents. The AZ-58 only output about 15 watts from the ray tube. I told him
that I still had my 1940s Aubrey Scoon replica and several AZ-58’s on the shelf. I told John Bedini that
the original Beam Rays instrument, from the documentation that we had, output about 50 to 60 watts
from the ray tube. He told me how I could make a test, by putting two AZ-58s together, which would
give me about 60 watts out of the ray tube.
I didn’t know it at that time but that test was actually the
way the original Beam Rays instrument worked. (pg. 36 Hist. Rife Frequen.)
The second Hartley Oscillator was also an RF Oscillator. It
has a tank coil and a variable capacitor for changing the RF frequencies.
Anyone looking at this schematic will notice that it does
not have any variable audio oscillator
Philip Hoyland’s Beam Rays
instrument was using RF frequencies not audio frequencies as previously
believed.
This discovery seems to be the missing part we have been looking for. It will need to be tested but it looks like it will be the truth!
It is something that we never thought of before so I hope it will work.
If you could explain better what John is doing I would apprieciated it since he hasn't updated his site in a feww years.
