Originally Posted by gmeat
Hi Mart,
You might wanna try hitting those batteries with a higher amperage than 800 milliamps but be careful as the transistors will heat up so make sure you have heatsinks on them and I personally like a fan on them.I find that the batteries charge better if you hit them with higher amperage for a little while,Another words hit them for maybe 5 or 10 minutes at about 1.5 amps then let them return to 800 or even 500 milliamps for say 15 minutes and i think you'll notice the batteries tend to like this sort of charging.Hope that helps and I thought those batteries were 6 volt golf cart batteries?.
-Gary
I am running them in sets of 2 (6V), so charging 6 of them at a time at 40V on the primary side... The RPMS at 4150..... Zzooooom.... I have normally just set it to the highest RPM, since I want a more ON time, and sharper spikes.
I can't wait till I figure out how to use my scope....
I felt all of the transistors and they are cool to touch while it is running. Since I am running this 24/7 I don't want any other arrangement.
Under my present setup, I am using an OLD analog power supply, it can't give me more than .8 AMP. but will consider your method when I start using batteries as my primary.
Mart
