Old 05-02-2012, 09:59 PM
MonsieurM's Avatar
MonsieurM MonsieurM is offline
Platinum Member
Send a message via MSN to MonsieurM
Now let us completely change perspective and have a look at us humans or more precisely the magnetic interaction between a woman and a man on a rather material level
just a quick search resulted in the following:
How to Attract Men - The Best Ways to Get His Attention |
Dress to kill. Use the colors red or pink to your advantage.
so why do you think red for women is so useful to attract the Male Pole ( no pun intended and get your mind out of the gutter )
which also is often represented by the Femme Fatale
Femme fatale - Wikipedia, the free encyclopedia
A femme fatale ( /ˌfɛm fəˈtæl/ or /ˌfɛm fəˈtɑːl/; French: [fam fatal]) is a mysterious and seductive ( vortex like ) woman[1] whose charms ensnare her lovers in bonds of irresistible desire, often leading them into compromising, dangerous, and deadly situations. She is an archetype of literature and art. Her ability to entrance and hypnotize her victim with a spell was in the earliest stories seen as being literally supernatural; hence, the femme fatale today is still often described as having a power akin to an enchantress, seductress, vampire, witch, or demon.
if you read this post with the colors you already have your answer
however their has been a long misinterpretation of the true meaning Femme Fatale
as an Antenna and a Fractal Construct ... the coherence still applies
a Harmonic Cascade Effect
An orderly arrangement between wave lengths establishes a connection between frequencies and fields. But for this connection to last, it must resonate to all frequencies and fields. This can only be accomplished through the resonate structure of golden mean pathways. a harmonic cascade effect
so if we were to consider the true Femme Fatale Construct she is the female definition of An Alchemist :
will have both Blue and Red joined together at all level
but if the woman only hangs unto the Shadow plane ( ie material red ) a dissonance is created
same principle as in Music :
In music, a consonance (Latin com-, "with" + sonare, "to sound") is a harmony, chord, or interval considered stable (at rest), as opposed to a dissonance (Latin dis-, "apart" + sonare, "to sound"), which is considered to be unstable (or temporary, transitional). In more general usage, a consonance is a combination of notes that sound pleasant to most people when played at the same time; dissonance is a combination of notes that sound harsh or unpleasant to most people.
ps : Plastic surgery for fashion is just that Plastic .....
Convicted spy Mata Hari made her name synonymous with femme fatale during WWI.
Mata Hari - Wikipedia, the free encyclopedia
----------------- a side note
just a thought ...well actually two
one: the Full moon is getting close and as usual can feel it
the second , based on what was just posted ... electromagnetically how would you translate that
covering the Female pole with a male pole of lower vibration ( red clothing ) to attract male poles of higher vibration ( man )
call it biomimetism or principle of correspondence
hint: see walter russell's coils ..... in his Spiral periodic table : Electric is Male and Magnetic is Female
