Old 04-28-2012, 08:43 PM
MonsieurM's Avatar
MonsieurM MonsieurM is offline
Platinum Member
Send a message via MSN to MonsieurM
Love it when the scientist think they discovered something new
The shape of things, illuminated: Metamaterials, surface topology and light-matter interactions
(Phys.org) -- Finding new connections between different disciplines leads to new – and sometimes useful – ideas. That’s exactly what happened when scientists in the Department of Physics, Queens College, City University of New York (CUNY), in collaboration with City College of CUNY, Purdue University and University of Alberta, leveraged mathematical topology to create an artificially nanostructured anisotropic (exhibiting properties with different values when measured along axes in different directions) metamaterial that can be switched from a non-conductive dielectric state to a medium that behaves like metal in one direction and like a dielectric another. The metamaterial’s optical properties was mapped onto a topological transformation of an ellipsoidal surface into an hyperboloid – and transitioning from one to the other dramatically increases the photon density, resulting in dramatic increase in the light intensity inside the material. The researchers state that by allowing topologically-based manipulation of light-matter interactions, these types of metamaterials could lead to a wide range of photonic applications in solar cells, light emitting diodes, displays, and quantum computing and communications.
[B] Randall Cole Roffe: Harmonic Resonance
[/B]
The application of the principles of one science into another is often neglected. Today we have a massive and growing volume of experimentally proven information that certainly does not always
find its every application.
In the real world, we can work from scientific theory, through experimentation, into an engineered result, but just as often we work via reverse engineering, from the
result back into the origin.
If we take a good look -- and listen -- at the whole of manifestation, and apply the principles of acoustics and music, and of the color wheel, the grand pattern that emerges is self-evident.More
than this, a possible explanation of a medium of transmission of a universal electrogravitational influence, as a plenum far more fundamental than an ether, becomes apparent. With this realization a
whole new understanding of physics also emerges, with awesome possibilities.
Randall Cole Roffe
Anisotropy ....who knew
