Old 04-25-2012, 08:32 PM
cinan cinan is offline
Member
Coil Driver circuit
And my last post today is suggestion for precise driver circuit based on ICL8035 and his equivalents.
You can adjust freq, duty cycle, and other parameters as will. Output is SINE / TRIANGLE / PULSE.
In this case I am only using PULSE output. But you can also use SINE and TRIANGLE outputs for
other purposes. See google for connection pictures.
Output signal is boosted via MOSFET driver and connected to tranzistor. Coil connection is also
highlighted. Picture is in att.
http://ww1.microchip.com/downloads/e...Doc/22019a.pdf
ICL8038 - Precision Waveform Generator/Voltage Precision Waveform Generator/Voltage ICL8038 [ICM003] - $5.00 : iStore, Make Innovation Easier
NTE864 NTE NTE Replacement Semiconductors
Cinan
