Old 04-18-2012, 07:06 PM
MonsieurM's Avatar
MonsieurM MonsieurM is offline
Platinum Member
Send a message via MSN to MonsieurM
Let explore another way of visualizing Amps ... think of it as an Analogy of sort ......
Anisotropy is defined as :
Anisotropy ( /ˌænaɪˈsɒtrəpi/) is the property of being directionally dependent, as opposed to isotropy, which implies identical properties in all directions. It can be defined as a difference, when measured along different axes, in a material's physical or mechanical properties (absorbance, refractive index, conductivity, tensile strength, etc.) An example of anisotropy is the light coming through a polarizer. An example of an anisotropic material is wood, which is easier to split along its grain than against it.
conventional current is defined to flow in the same direction as positive charges. So in metals where the charge carriers (electrons) are negative, conventional current flows in the opposite direction as the electrons. In conductors where the charge carriers are positive, conventional current flows in the same direction as the charge carriers.
or if you prefer "Left Chiral" vs "Right Chiral"
ponder on that
