Old 04-17-2012, 04:45 PM
jake's Avatar
jake jake is offline
Senior Member
Awesome
@ Web000x:
Good Grounding is on the horizon. What do you think of Eric's recommendation of the 80 ground radials? Is this needed in addition to the 16 ground rods or can this be used in place of the 16 rods. It would be easier to lay out compared to the rods. but the center rod will be 10-20' deep in good soil.
@ xee2:
I wish it was that easy. Problem is the coil I am using now was calculated to have a specific diameter, hight and length. I can't change one without screwing up the others.
BUT I have a slightly smaller diameter cardboard tube. I think it would be a good idea to build a setup based on you way of thinking then I could compare the two. Smaller diameter will allow more turns greater induction for same length of wire.
Can't wait to get out of work.
