As the distance between the primary and secondary is increased the resonant frequency of the coil increases ~5-10kHz per inch and the amperage measured between the can and the top of the secondary also goes up.
Any ideas?
I'm playing with the secondary and primary like in
I did not post this in the Dollard thread because I am missing the split ring on top. I am also using more of a current indicator with an adjustable range for readings so there are no actual values I cam use.
Currently the best frequency is 2200kHz. But this will change(+\-500kHz) depending on the evil clip leads being used and how they are laid out. I flattened some 14 gauge and need to get that soldered in place.
