  #184 (permalink)
Old 04-29-2008, 01:03 PM
nismotekk nismotekk is offline
Junior Member
thank you
Redmeanie,
Thanks for your response, I am trying to educate myself as much as I can on hydrogen and the production of it. I was trying to increase my gas mileage and reduce my emissions, I had not thought about a fuel conversion, is this possible? Will the gas be drawn into the motor throughout the entire RPM range? That is why i asked if the system could be pressurized. I have used EFIE devices before, I have used APEXI products as a piggyback system to my ECU. Those devices interrupt the signal from the MAF to the ECU. Their device tells the ECU that there is more or less air coming in than actually is. The system is totally user tunable.Would that work on this system? Or would you need an o2 device? Also, are these systems safe to install for others? Is there an approximate number of people using using "boosters"? How long have you guys been using them safely? Thank you for any imput, Chris
