Old 04-08-2012, 08:10 PM
MonsieurM's Avatar
MonsieurM MonsieurM is offline
Platinum Member
Send a message via MSN to MonsieurM
as we have previously dicussed Tourmaline being A Boron Crystal:
here are a few applications using Tourmaline ..... note also the use of Aluminum (see periodic table )
Tourmaline, "The Electric Stone", is exploited in hundreds of patents. Here are several select patents and articles of especial interest in regard to the production of electricity by tourmaline, and agriculture.
See also : T.T. BROWN / Petrovoltaics ... Earth Batteries ... Marcus REID / Crystal Battery ... John HUTCHISON / Hutchison Effect &c...
MANUFACTURE OF SEMIPERMANENT BATTERY
JP7302596
1995-11-14
Inventor(s): KITA MASAYUKI; KITAMURA KAZUO; ASATANI TAKUO
Applicant(s): OYO KOGAKU KENKYUSHO KK
Classification: - international: H01M6/06; H01M6/16; H01M10/02; H01M6/04; H01M6/16; H01M10/02; (IPC1-7): H01M6/06; H01M6/16; H01M10/02
Abstract -- PURPOSE:To provide a semipermanent battery by putting far infrared radiation ceramic powder or a far infrared radiation ceramic powder pack in an inside electrolyte solution of a primary battery or a secondary battery, and naturally charging to recover the original potential. CONSTITUTION:Pulverized tourmaline fine powder belongs to far infrared radiation ceramics, and is put in an electrolyte of a battery as powder or being packed. It was found that even if the battery is discharged, the potential does not change. When a lithium battery was tested in the condition of 500mA discharge for 10 minutes and rest for 4 hours, voltage did not vary over 7 month. It is thought that the recess of an ionic crystal of the powder is charged positively and the other end is charged negatively to produce potential, dynamic energy such as temperature is converted into electric energy, and in addition by electromagnetic radiation from the far infrared radiation stone, oxidized electrolyte is reduced.
PERMANENT ELECTRODE FIBER AND ITS PRODUCTION
JP6184808
1994-07-05
Inventor(s): KUBO TETSUJIRO; KAWAGUCHI KOTARO
Classification: - international: D01F1/10; D01F2/06; D06M11/00; D06M11/49; D06M101/00; D06M101/02; D06M101/06; D01F1/10; D01F2/00; D06M11/00; (IPC1-7): D01F1/10; D01F2/06; D06M11/49
Also published as: JP2715034
Abstract -- PURPOSE:To provide a permanent electrode fiber composed of a regenerated or synthetic fiber containing a tourmaline powder finely pulverized by a tromill in combination with a highly orientated crystalline tourmaline as a permanent electrode substance distributed in the fiber surface layer and capable of giving a favorable electric stimulation to the human body so as to activate the human body and to provide its production method. CONSTITUTION:A permanent electrode fiber containing a permanent electrode substance highly orientated and distributed in the surface layer of the fiber is formed by mixing the permanent electrode substance having electrodes at both the ends of the crystal structure in a regenerated or synthetic fiber.; The permanent electrode fiber containing a permanent electrode substance highly orientated and distributed in the surface layer of the fiber can formed also by uniformyl mixing and dispersing 1 to 5wt.% natural or artificial permanent electrode substance powdered into <=1mum liquefied raw material such as a regenerated or synthetic fiber or blending a suspension of a titanium oxide- containing permanent electrode substance powder with liquefied raw material such as a regenerated or synthetic fiber and spinning it through a spinning nozzle while allowing it to pass through an external magnetic field.
Artificially-synthesized tourmaline crystalline substance and its preparation method
CN1800014
2006-07-12
Inventor(s): CHEN YANDONG [CN]
Applicant(s): SHENZHEN FANGHAO INDUSTRY CO L [CN]
Classification: - international: C01B33/20; C01B33/00
Abstract -- The invention discloses an artificial synthetic tourmaline crystal and synthetic method, which consists 2-10 percent tourmaline and 90-98 percent mineral, wherein the tourmaline and mineral are grinded into grain size mixture less than 15 nm, which is grinded into grain size more than 15 nm after melted at more than 1600 deg.c. The invention can produce large amount of negative ion, which absorbs artificial synthetic tourmaline crystal with positive charge odor, bacteria, smog and harmful gas.
Dynamoelectric monomers, and self-discipline generating set of possessing the monomers
CN1960051
2007-05-09
Inventor(s): QUJING BOMEI SHANG [CN]
Applicant(s): LIUJIA INT TRADE TIANJIN CO LT [CN]
Classification: - international: H01M10/36; H02J7/00; H01M10/36; H02J7/00
Abstract -- Pressing powder of tourmaline covered by lithium metal produces the disclosed power generation unit. The invention also discloses self-discipline generating set composed of multiple connected power generation units, as well as not contact charging circuit system including combinations between power generation unit and electromagnetism, or the unit and light, or the unit and solar energy. When accomplishing charging to self, the power generation unit can transport redundant electric energy to other power generation units at a time. The invention also includes micro intelligent operation system CPU in use for controlling and managing generating, charging electricity and transporting electricity to other units. In condition of without external electrical source, the disclosed power generation unit self can produce stable and long lasting electric energy.
Tourmaline nano metal oxide and preparation method thereof
CN1990385
2007-07-04
Inventor(s): LI XUECHENG DING [CN]
Applicant(s): SHANGHAIHUZHENG NANO TECHNOLOG [CN]
Classification: - international: C01G1/02; C01G1/02
Abstract -- The invention relates to a nano tourmaline metal oxide, which especially can increase anion release efficiency. Said metal oxide comprises tourmaline metal oxide with grain size being 5-30nm and nano silver granular with grain size being 0.2-1 um; nano silver granular is attached to the surface of tourmaline metal oxide. The invention makes use of the tourmaline metal oxide coated with nano silver granular and the powder phase of tourmaline metal oxide to dramatically increase the release amount of anion and far infrared rays, which improves treating effect for human body. The invention aslo relates to the method for preparing said nano tourmaline metal oxide.
.....more next post
Signs and symbols rule the world, not words nor laws. -Confucius.
