Old 04-04-2012, 03:38 AM
thugugly thugugly is offline
Member
Red face
ufo,
Actually, i jumped while sliding the metal rod into the core. I forgot about magnetic effects and when the rod was pulled in i was looking at the amps.
Maybe hutchinson used two fields, one to polarize the object and one to move the object.
I did hook up a small radioshack motor in parallel with the light and it worked very well, light dimmed, 1amp draw ran motor and light really well.
I haven't had a chance to set up the drill motor yet, and I'm still trying to find a good cap size for timing circuit.
In terms of wanting to use high voltage pulses, how high do you mean, greater then 20 kv?
I used my circuit to run flybacks and car coils for my don smith set up, 10-20kv, and i know you can make car coils fire, + and - together, called anti-parallel, I've done that.
Thug
