Old 04-03-2012, 08:12 PM
Mad Scientist Mad Scientist is offline
Silver Member
Originally Posted by Ufopolitics View Post
The last and wonderful thing we need to do is to ISOLATE the low voltage signals from Oscillator to Gates, from the Source-Drain Higher Voltage that also needs to be regulated to higher levels...where I plan to use an Opto-isolator chip, to do this job.
When I originally designed this circuit it was meant to be use as a pulse width modulated signal for a motor speed control. As such I have used it with both P & N type fetís and it has worked well.
However there is no reason they cannot drive an opto-coupler. The chips output is an open collector transistor (emitter to ground) and able to carry 16 milliamp.
