Old 04-03-2012, 07:27 AM
petar113507 petar113507 is offline
Senior Member
A little bit I co-related about our fractal antenna. Figured here would be as good a place as any to drop the info....
The Pineal Gland - GoldRing: Enlightenment & Abundance
The Pineal gland is cone shaped and is located in the
middle of the brain behind and just above the Pituitary gland.
The Pineal gland contains pigment similar to that found in
the eyes and is connected to the optic thalami, hence it controls
the action of light upon our body. The Pineal gland is located
in the posterior end of the Third Ventricle of the brain and
the Pituitary gland is located in the roof of the third ventricle.
It is said that the joining of the essences of these two glands
in the third ventricle is what opens the Third Eye.
The Pineal gland acts in two ways to inhibit the action of
the Pituitary gland. First, the Pituitary gland is responsible for
activating adolescence and the beginning of sexuality, a
and the Pineal gland checks the Pituitary gland to prevent
premature sexual awakening. Second, human thought is
regarded as a result of suspended action, and the Pineal gland
inhibits the immediate discharging of thoughts into action.
Tesla thought that each thought he had was from the enviroment -- that he was essentially a puppet. If we could follow each thought from each cause, until the externalization of that thought form -- I'd imagine we might see in part, the pineal gland's role in "suspending" each thought form until the time is right, (until the frequency phase matches the enviroment) soas to be synergestic (intentional) or reactively provoked from/to the enviroment.
this struck me as a direct corelation between Walter Russell's centripital winding from large nebulous gases into dense solids, and how our pineal gland is the piloting fulcrum of our brain.
Russell Illustrates this in his periodic table of elements, beginning from 1, the least dense -- contracting in successive efforts in the order of 2,3 and finally the most dense -- 4.
https://www.evernote.com/shard/s192/...40dd795db6e8ef
1, Where the electric pole is winding from its most expanded position -- slowest rotation
2, you can see the cone gets more narrow
3, the cone becomes successively more dense until it contracts into a single point/plane
4 -- the highest rotation, slowest revolution
Another image, showing the the opposite perspective -- from the magnetic perspective, instead of the electric pole...
https://www.evernote.com/shard/s192/...ade77867be913d
Russell's tornado principal, showing the wide rotational axis contracting into a single focal point. When all of that expanded potential is compacted into such a small area instead of around a wide axis, it has much greater precision and intensity in force.
https://www.evernote.com/shard/s192/...5b971632e1d176
Here is the though which I wished to expand upon, to connect Russell's concept of matter, with our pineal gland -- the piloting fulcrum of our puppet-bodies.
https://www.evernote.com/shard/s192/...6a8c646adc850c
Because if we consider our Unfolding, like the unfolding of a blooming flower -- even in the shape of something like a rose...
FullHD Rose Timelapse 02 - YouTube
And compare the regions of the brain activated during the unfolding of our lifetimes -- from youth, it begins from a single point -- like a seed contained in the center of the unfolding flower unfolds while, while its body expands throughout its lifespan. Now, the seed in the center of the rose unfolds, might be somewhat akin to the unfolding of the electric field in our pineal gland. The petals, of the rose flower, would "touch" different cortexes of our brain as we get older, and tap into our conscious abillity to intentionally manapulate/re-write our behaviors and functions of our puppet bodies.
http://www.crystalinks.com/chakracones.jpg
You dont give a new driver the keys to a brand new car -- you teach them to drive properly first
the later systems which are put under our conscious effort of self-control might become chemically mature after a certain level of growth or development from the individual...
And so, our electric fields are growing, whether we like it or not....
