Old 03-31-2012, 05:42 PM
Parav Parav is online now
Member
Originally Posted by Parav View Post
Hi Jake,
To solder together thick pieces of solder , an ordinary soldering iron just does not provide enough heat as the heat gets dissipated into the thicker material too easily.
Use a propane torch -like what plumbers use to solder copper pipe fittings.
Also , make sure that the copper pipe is lightly sanded at the area you want to soldered -to get rid of the oxidization---or use that flux paste plumbers use to help clean off the oxidization while it's being soldered . Good luck--[I] hope this helps.
Paul
oops typo-- I meant when soldering two pieces of thicker copper together
