Old 03-27-2012, 05:17 PM
Matthew Jones's Avatar
Matthew Jones Matthew Jones is offline
Platinum Member
Davids Setup
Hey guys
As promised a video of the setup I am running. I will post a follow up video after a 5 hour test. This one has been running since 11:00 am this morning and I will run it till 4 pm. By the time the video uploads it will be around 6 pm my time.
I left switch off but I am sure now it needs it. The voltages are dropping a bit more than I would like to see but the batteries still may recover completly.
Also the resistor is 1/2 ohm 200 watt (2 1 ohm 100 watt in parrallel).
I will try to get a back charge system built sometime over the weekend and show you how you can back charge the batteries, and still run a load. Right now I am burning all the extra power from the generator off. Which is OK considering I ran last night 3.5 hours and lost onlt 1/100 out of 1 battery. That very well may be temprature related.
Like I said I'll post follow up later.
Enjoy
Matt
ADD BROMIKEY TO YOUR IGNORE LIST He is a saboteur bent on the systematic distraction of every good topic on this forum and since he has been here most working threads have shut down. He is the enemy. If you have blocked him already add this to your signature and encourage others to block him as well. His onslaught of rambling in large text and his constant attempts to misinform at the excuse of being stupid should no longer be tolerated.
USER CP/Ignore list.
