Old 03-26-2012, 10:41 PM
Matthew Jones's Avatar
Matthew Jones Matthew Jones is offline
Platinum Member
Originally Posted by boguslaw View Post
Ok, now I think we can replace bad battery with a large capacitor, but custom made. Follow Tesla patent 567818. Just metal plates in concentrated salt solution.
Doesn't seem to be any difference between that patent and todays Aluminum Electrolyte capacitor.
I would first suggest learning how to properly destroy the battery you have availible.
The battery I am running the system off of is a 1100 CCA battery for a catepiller tractor. It was used for 8 years and died one winter after no activity for about 6 months.
The PH is Normal the Hydrometer does not give a reading, the battery holds about 3.5 volt standing and droips to nothing with 1 ohm resistor for a load.
The primary batts are 1500 cca Interstates tractor batteries
I'll also tell ya I am using a Razor Scooter Motor for both the motor and generator (Coming soon).
This is the 1 ohm 100 watt resistor but ceramic, but this is the equavalent
I have 1/0 wire with copper connectors to everything and real short leads to the motor/generator, and all copper connectors.
The motor free wheeling runs at 1.1 amp.
Matt
ADD BROMIKEY TO YOUR IGNORE LIST He is a saboteur bent on the systematic distraction of every good topic on this forum and since he has been here most working threads have shut down. He is the enemy. If you have blocked him already add this to your signature and encourage others to block him as well. His onslaught of rambling in large text and his constant attempts to misinform at the excuse of being stupid should no longer be tolerated.
USER CP/Ignore list.
