Old 03-24-2012, 03:28 PM
MonsieurM's Avatar
MonsieurM MonsieurM is offline
Platinum Member
Send a message via MSN to MonsieurM
another re post to get the thought across
Change your body from 'Acidic' to 'Alkaline'; according to Cancer specialist Dr. Leonard Coldwell, this alone will stop cancer from growing.
Dr. Leonard Coldwell states that every cancer can be cured within 16 weeks. Dr. Coldwell states how that's possible in this video.
Every Cancer Can be Cured in Weeks explains Dr. Leonard Coldwell - YouTube
I just wanted to mention this for the curious mind and important ...For most of the research done on medical use of electromagnetic waves; one aspect has been overlooked and that is to obtain optimal results such as in the use of Violet rays....the Antenna / the patient has to have followed an Alkaline Diet...In this research I have found that Alkaline Water and Diet enhances the healing aspect of the body.
---------------------from a previous post The Golden Tractate of Hermes Trismegistus applied to electromagnetism
According to Marcel:
This structuring is best assayed with a UV spectro-photometer where one finds an increase in UV absorption due to an increase in the water bonding from the water forming chains on itself. The magnetic moment of this structured water is increased by 0.07 gauss and there is also an increase in the pH and dielectric conductivity.
sorry for the repetition;
key word quartz
Edgar Cayce often recommended animated ash and ultra-violet light therapy for persons suffering from cancer. The readings stated that the animated ash would increase the oxygen in the body and assist the immune system in fighting the cancer.
" Animated ash was a form of bamboo that was reduced to activated charcoal by means of a partial vacuum electrical carbon arc process. The resulting ash (alkaline ) was taken internally
Cayce’s dietary recommendations for cancer tended to follow several key themes:
• Eat a diet that tends to produce a balanced pH in the system with
a tendency towards alkalinity.
Imagine a medical tool where you take a UV laser pointer or violet ray and place a healthy cell , like stem cells, contained in a quartz lens and then shoot the UV laser through it, which would carry the healthy information in the beam, to heal sick people .
so to increase the UV effect, an Alkaline diet would be recommended
Cancer Healing & Spirituality (4): Edgar Cayce on Cancer Causes and Treatment (2)
Fact: The miracle water of Lourdes, France had a pH of 9.5.
