  #5 (permalink)
Old 05-05-2007, 11:45 PM
lighty's Avatar
lighty lighty is offline
Senior Member
@Aaron
@Peter
Thx for the explanation. Now I seem to understand a principle behind it a bit better than before. I did a number of experiments but to be honest I didn't see any difference between these two configurations. I trust Bedini's experience but I also trust in understanding underlying principles rather than simply replicating them.
Also regarding the positive and negative poles of Lead-Acid batteries I cannot but to remember what Leedskalnin described in his experiments and that I replicated and verified. He stated that there is always a larger number of "north pole magnetic particles" in the battery and that they're all sourced from the (+) pole of the battery. I did replicate his PMH and did a number of precision measurements. What I've found is that Leedskalnin was correct in his assertions- no matter what you do with the PMH core, no matter how you polarize coils there will always be a disbalance of magnetic poles in the PMH. The North will always be geometrically predominant in the PMH and it will always be somewhat stronger. I repeated the experiment several times using professional gaussmeter and it always showed the same. One half of PMH is always spatially bigger than the other one and it's always the north pole. So if a north pole is produced by the tiny magnetic particles from the (+) pole of the battery then Leedskalnin was correct in assuming there is more north pole magnets or rather (+) pole particles in the battery.
I'm getting way offtopic here but it just strike me as oddly connected to your explanation.
