Dam foundations and height of the dam above the bedrock
The top of the Dow-Dam has an elevation of 780 metres by design.
Image also hosted here
The lowest elevation of the current ground surface of Coire Glas along the line of the proposed dam is 463 metres and subtracting 463 from 780 is how the initial value of 317 metres for the nominal height of the dam above the existing surface used in previous diagrams was arrived at.
However, the glacial deposit of as yet unknown thickness is to be removed before building the foundations of the dam within and upon the bedrock.
Although the lowest surface elevation along the line of the dam of the bedrock too is unknown a formula relating the
Height of the Dam Above the Bedrock (HDAB) to the
Glacial Deposit Depth (GDD) can be easily stated.
HDAB = 317 + GDD
Examples.
If the GDD turns out to be 13 metres then the dam will be 330 metres tall.
If the GDD turns out to be 83 metres then the dam will be 400 metres tall.
I propose that the height of the Dow-Dam be as tall above the bedrock as it needs to be to keep the top of the dam at an elevation of 780 metres no matter how deep the removed glacial deposit layer turns out to be.
My approach may well differ from the SSE's approach. The SSE have said that their dam will be "92 metres" high and they may stick to that without having any goal for the elevation of the top of their dam.
As the diagram indicates, I propose to secure the Dow-Dam to the bedrock by massive piles inserted and secured into shafts which would be drilled into the bedrock.
