  #4 (permalink)
Old 05-05-2007, 07:27 PM
Peter Lindemann Peter Lindemann is offline
Senior Member
For what its worth...
Originally Posted by lighty View Post
I always wondered why did Bedini put thyristor in the "negative" branch of the discharge circuit? It seems to me as if it's all the same if one puts the SCR's anode directly to the positive end of the capacitor and then use it to discharge the cap into the battery or if one puts cathode of the SCR to the negative terminal of the cap and then discharge the cap into the battery.
What's the difference? I mean, I've found some very vague explanation in Bedini's latest patent about polarization of the SCR being related to the type of energy used in the circuit but to me it seems as if the SCR is simply the one way fast switch that's being used to close the circuit (or to be more precise to discharge the capacitor to the battery) so it shouldn't matter if one connect thyristor either way as long as the proper polarity is observed?
Could somebody explain the rationale behind the kind of configuration used by Bedini in his patent?
Dear Lighty,
As Aaron just explained, John has looked at switching both the negative and the positive sides and studied the situation in depth. From a theoretical point of view, there doesn't seem to be any reason for a difference. But on the bench, in the real world, there are differences. John has his own way of explaining it, and that's in the book "Free Energy Generation". Here is my way of seeing it. In a lead-acid battery, all of the action is on the positive plate. When discharging, the lead peroxide of the positive plate is donating oxygen atoms to join with hydrogen from the H2SO4 in the electrolyte to be converted to new water molecules and free sulfate ions that deposit on both the positive and negative plates. When charging, this process is reversed, but the action is always on the positive plate. When you try to charge the battery from the negative plate with a big push of negative electrons, the charge has to travel through the electrolyte to get to the positive plate where the reformation of the lead peroxide IS the restoration of the chemical charge. When the positive plate is potentialized, the battery charges differently, at lower temperatures and with less off-gassing.
These things can not be figured out simply by THINKING ABOUT IT. You have to run the experiments if you want to learn anything. And that's the difference. John has run every conceivable experiment in this regard, and that's why he knows more than the rest of us!
I hope that helps.
Peter
