Originally Posted by Lemontree
can there be more miles per gallon if we can make more HHO gas?
a normal car have one generator, which can make power output about 600-1000W. and not all of this power can be used for hho, because there are other needs for electricity, such as lamps, batt charging a.o.
- at the end we can take only 200-300W. but if using two generators - than summary power for HHO can be about <1000W in ideal conditions. this makes about 3 liters hho per minute, compared to ~1 liter per minute with one generator.
car audio enthusiasts sometimes use two generators, and also couple of batteries, to supply special unnormally loud audio systems for loudness-drag championships.
The 1.5 to 2.0 Liters per minute is good enough for UP TO a 40% incrase in mileage in MOST small and midsize vehicles. If you try to go higher with more Gas then you are getting into the realm of having to modify timing along with other pretty complicated things. So Yes you can get more mileage increase out of more HHO but at a cost. So in the spirit of keeping it simple a "Maximum" of a 40% increase should be expected.
