  #50 (permalink)
Old 04-11-2008, 12:57 AM
ashtweth's Avatar
ashtweth ashtweth is offline
Senior Member
Send a message via Skype™ to ashtweth
Hi all,
i just loaded the solid state charger with a conditioned 7aH battery. On
the input was a TINY 1.3aH battery.
The start voltage on the 7ah was 12.57 volts
The start voltage on the 1.3ah was 12.96 Volts
I put the 1.3 aH battery as the input on the solid state, and tuned
the pot right down i could tell the draw, i heard the ringing on the
tri filla coil., so i know some thing was going in.
I put the 7aH battery on charge and left to it on to see what happened.
The 7Ah battery charged to nearly 13.30 volts, the 1.3ah lost it after
nearly 40 minutes to zero.
I loaded the 7ah on a fixed resistor at the c20 rate, the battery held
charge from 12.89 to 12.69 Volts (original was 12.57).
There you go, a 1.3aH battery can charge a 7aH CONDITIONED battery.
Here is the snap more to come.
http://img521.imageshack.us/img521/3491/41821419mg4.jpg
At the front you can see the Tiny 1.3ah hour 12 volt battery, in the
middle is Clives solid state i posted a while back, at the end is the
7aH battery showing the charge.
video coming , ill do the test again.
Ash
My Q for Peter is, can a 1.7aH battery charge a 7aH battery conventionally COLD?
