  #763 (permalink)
Old 04-10-2008, 08:58 AM
elias's Avatar
elias elias is offline
Senior Member
Encouraging Results
Originally Posted by Jetijs View Post
I connected the output of the motor to a battery. I put an amp meter on the positive side and the scope leads across the amp meter to see the output current waveform. Then I adjusted the duty cycle of the pulses and observed how the waveform changes. As I noticed before, there is a sweetspot in duty cycle where it is possible to get the best recovery and it is somewhere at 56-57% positive duty cycle.
Jetijs
Dear Jetijs,
Thought to share an observation of mine to you. I had found out before that if I connect a parallel capacitor (The capacitance is not very much important, 330uF for example) to my output battery it would increase the recovery to the battery. The capacitor seems to be able to "catch" more of the recovery and redirect it to the battery. The internal Impedance of the battery is the main cause of this effect I suppose. I suggest you using a capacitor parallel to your battery and comparing the results. Good luck with your marvelous work!
Elias
