Old 02-25-2012, 06:19 PM
FRC's Avatar
FRC FRC is offline
Silver Member
Another run
I did another run after only allowing batteries 1 and 2 to rest for about three hours. This time with a larger battery 3 (same battery I had tried before but turns out there was a connection problem that time). Much better results this time. 40 watt light would run longer before cutting out, and run continuously with just a small load on motor. Next I tried hooking up a small 2 amp charger off the inverter and it worked well charging a fourth battery. Next the second motor again and the RPM's increased. All ran nicely with this arrangement. I
shut it down after about 45 minutes. I hope I will not ruin the good batteries
going over half an hour and not letting them rest longer.
George
