Old 02-23-2012, 09:48 PM
FRC's Avatar
FRC FRC is offline
Silver Member
Originally Posted by nvisser View Post
They use 24V batteries on both sides. No tesla switch configiration.
The system was comprised of a series-wound, brushed, DC motor (slightly modified) powered by one bank of two 12-Volt batteries (102 Ah) wired in series for a 24-Volt output. The company says the back-EMF is harvested into a second, identical battery bank, which is also wired in series. These two banks are periodically cycled, trading places in the circuit, and the net charge stays essentially the same, across both banks. The optimized cycling of power and storing of the back-EMF are all controlled by a proprietary circuit board and software developed by the inventor. The motor shaft is connected directly to the shaft of the AC generator, which spins at 3,000 rpm to produce 5 kW of power at 50 Hz, 220-V.
" No tesla switch configuation, (DC motor slightly modified) " Sounds like it could be more like a Lockridge device, but with the electronic/software system as opposed to mechanical.
George
