Old 02-22-2012, 09:19 PM
Turion's Avatar
Turion Turion is online now
Platinum Member
I have only been able to get it to work with lead acid batteries. You're welcome to try something else, and it would be good to eliminate other types of batteries as possibilities, because that would give us even MORE information.
If you read what we've been saying, you MUST match the load on battery three to the load on the motor. You do this by putting a load on the motor and then adding small loads to battery three and waiting. The second you add a load to battery three, the motor will speed up. If you wait a few minutes it will speed up AGAIN if the load is matched. If not, keep adding or subtracting loads until you get a match.
"I aim to misbehave" Malcolm Reynolds
"Try Not! Do or do not. There is no 'Try' ". Yoda
