Old 02-18-2012, 10:11 PM
SkyWatcher's Avatar
SkyWatcher SkyWatcher is offline
Gold Member
Hi folks, again, this looks very similar to magnacoasters first videos.
Where he had a bedini type rotor energizer feeding radiant pulses to a dead battery i believe, then he would hook a standard inverter to his car battery and would try to run medium loads like a power drill and the inverter shut off sounds and lights would kick in.
Then when he turned on his energizer and then tried to run the loads off the inverter connected to his large dead battery, it would run the drill and many other loads.
So something similar to this setup is happening inside the battery with this setup.
I don't think the 3 batteries are needed in all setups, there is an effect here inside the battery that needs to be figured out, I bet bedini knows all about it and I bet the Watson machine used a similar principle.
peace love light
tyson
