  #132 (permalink)
Old 04-02-2008, 07:53 AM
kumaran kumaran is offline
Member
Hi Lemontree,
Originally Posted by Lemontree View Post
i want to suggest not to drill each plate for screw inserting, but end without full plexiglass enclosure, just screwed plates togeather and gas output on one plexiglass side. i think it is a good idea to save/economize the time and effort, and also materials without loosing much of qualities. because, it is not easy to drill a lot of holes into 1mm thick stainless steel, even with proper instruments.
I have reason for doing in this way. If you see 8 plate series cell link, I did exactly like you said. When the pressure increase (over pressure), leakage can happen from vinyl sheet because no support at centre of the cell. Also, you need to find suitable size nylon tube to seal place where threaded bolt goes through. Experience from 8 plate series cell, I made changes in 13 plate series cell to drill holes on each plates and vinyl sheet.
Yes, its time consuming process but worth in the end. I use three diffrent drill bits to make single hole onto SS plate. Now I can tighten the nuts more to make no gas or electrolyte leak from drilled hole. No matter how much pressure builds up inside electrolyser casing, no electrolyte leakage will happen from vinyl sheet electrolyte seal . Another advantage is I can reduce electrolyser size a bit.
Kumaran - nice idea to put all electrolyser in plastic container, also i had become a bit nerous, after several explosions, so safety precaution os always a good idea. i am thinking of using some face shield, like woodworkers use, but who knows, is it really necessary, or it is just nervous thoughts
No matter what, safety comes first. Use softdrink bottle (coke bottle) as safety bubbler. Do not use hard plastic. You check some exploded bubbler made from hard plastic in 8 plate series cell link. If you want to use homemade flashback arrestor (like you are using right now), make it after softdrink bubbler.
You need to use longer bronze fine wool container. This could be the cause of explosion happens where the fire by passed your homemade flashback arrestor. You know what, when I first tested hydroxy torch, I wear full face helmet as precausion. My hands were shivering to during torch lighting. After that enjoy the success.
