  #130 (permalink)
Old 04-01-2008, 11:17 AM
Lemontree's Avatar
Lemontree Lemontree is offline
Junior Member
Kumaran - thanks a lot for advice! also, it was pleasure to see your project! sorry for not refering to your project, somehow i saw this setup long time before, and even forget about it, that time it seemed to bee too complicated for me
i will try to find some vinyl sheet. of course, i am not shure about this black rubber, because it is not already correctly tested, only few days it is assembled, so, will see, how it behaves
i want to suggest not to drill each plate for screw inserting, but end without full plexiglass enclosure, just screwed plates togeather and gas output on one plexiglass side. i think it is a good idea to save/economize the time and effort, and also materials without loosing much of qualities. because, it is not easy to drill a lot of holes into 1mm thick stainless steel, even with proper instruments.
Jetijs - this was your's idea, to test the "screwed plates" design
________
Kumaran - nice idea to put all electrolyser in plastic container, also i had become a bit nerous, after several explosions, so safety precaution os always a good idea. i am thinking of using some face shield, like woodworkers use, but who knows, is it really necessary, or it is just nervous thoughts
