  #6 (permalink)
Old 03-20-2008, 02:02 AM
Sharyn's Avatar
Sharyn Sharyn is offline
Senior Member
Send a message via Skype™ to Sharyn
[quote=MoxieMags;17447] I also like the fact that I can have another friend test and confirm my answers. That was very reassuring when I was just starting out.
It is kind of fun to see that getting a second opinion by anyone else shows how accurate this process is.
Hi Maggie,
I would just like to add a note of caution here. This technique is not infallible, particularly when used on behalf of others. It is really testing your own beliefs & only you can be 100% certain of the answers you are getting for yourself. So a friend may be correct some of the time, but they won't be all of the time. Many other factors can come into play.
I know in your case, that you had tested yourself first & were only seeking confirmation in the early days, but the situation can & does arise where the other person will receive different results. So in that case who are you going to listen to? It tends to muddy the waters a bit. It is far better to practise the technique a bit & then learn to go with trust in yourself.
I hope I haven't opened a can of worms here as I don't want everybody running around on the forum suddenly deciding they can advise somebody else what Paths modules they should use because of this.
So for everyone reading this - Please use this method to find out what PATHS modules are best suited for yourself.
Love, Light & Blessings
Sharyn
