  #11 (permalink)
Old 03-17-2008, 11:22 PM
Aaron's Avatar
Aaron Aaron is offline
Spiritual Entrepreneur
Fluoride Master
Hi Doug,
This can take out fluoride:
FluorideMaster Whole House Fluoride Water Filtration System
The FluorideMaster™ Whole House Fluoride Water Filtration System is an effective chemical-free technology exclusively available Factory-Direct through Vitasalus/Equinox Products. Our highly-specialized FluorideMaster™ system utilizes premium-grade FluorideMaster™ media and is designed to remove up to 99.9% fluoride, sediment and/or particulate matter from all of the water entering your home for approx. 3 years or 300,000 gallons.
The FluorideMaster™ is shipped Pre-Assembled (tank comes pre-loaded with high-grade media) and Ready-To-Install which greatly simplifies the installation process and significantly reduces installation time and cost.
We also provide our industry-leading, 100% Customer Satisfaction Guaranteed Warranty including: 3-Year prorated warranty; plus a 1-Year Defect-free warranty on materials and workmanship.
Without a doubt, the FluorideMaster™ is the highest quality and most affordable whole house fluoride water filtration system available anywhere in the world!
Features and Benefits:
• FluorideMaster™ Whole House Water Filtration System utilizes premium-grade FluorideMaster™ media and is designed to remove up to 99.9% fluoride, sediment and/or particulate matter from all of the water entering your home for approx. 3 years or 300,000 gallons. • Shipped Pre-Assembled (tank comes pre-loaded with special media) and Ready-To-Install which greatly simplifies the installation process and significantly reduces installation time and cost. • No chemicals, electricity, drain-line or media regeneration required. • No maintenance required on the main system—only 0.35-micron prefilters need be replaced approx. every 6 months to extend the life of the system and insure optimal system performance. • Rust proof wound fiberglass polyethylene tanks feature 125psi operating pressure. • Includes our industry-leading, 100% Customer Satisfaction Guaranteed Warranty including: 3-Year prorated warranty; plus a 1-Year Defect-free warranty on materials and workmanship.
How does the FluorideMaster system work?
The FluorideMaster™ Whole House Water Filtration System, completely loaded with our premium-grade, high-performing FluorideMaster™ media, is designed to remove up to 99.9% fluoride, sediment and/or particulate matter from all of the water entering your home for approx. 3 years or 300,000 gallons.
STAGE 1: The 0.35-micron prefilter, housed in a clear canister for easy visual inspection, is a replaceable cartridge that mechanically filters down to 0.35-microns. This important first stage filters the undesirable sediment or particulate that may be present in the water supply so that it doesn't clog the main filter and reduce water flow and/or filter life. Also filters out copepods and cysts which may be present in your water supply.
STAGE 2:
The water supply passes through over 30 pounds of our premium-grade, high-performing FluorideMaster™ media which is designed to completely remove or significantly reduce all of the fluoride common to city/municipally treated water.
I'd call these people at their toll free #, they have great customer service.
Ask how their filter takes out the fluoride when most "filters" do not.
Vitasalus, Inc./Equinox Products, LLC
1301 Rankin
Troy, Michigan 48083 U.S.A.
(Toll Free) 1-877-284-5042
(Outside USA) 248-585-8815
(Fax) 248-583-6950
Office Hours: Mon-Fri, 9am-7pm (Eastern Time)
Sat, Noon-5pm (Eastern Time)
