Originally Posted by maggieb
Hi,
any suggestions for really good water filtration?
I am mainly concerned about fluoride. I don't want to buy bottled water for environmental reasons.
I read that Reverse Osmosis is the best option for this, but would appreciate any first hand info.
Thanks!
The best I have found is distillation with glass :-)
Yes this is not a method of filtration, but it seems to be the best way to most of the chemicals of the mix that can harm our bodies.
I currently use a system called a Berkey light.
Berkey Light Water Filtration System - Plus Model with LED Lights in Base
It has an additional filter for flouride. I really wanted to get distilled water myself, and then add back minerals that are organic ( made from goat's milk ) but the cost is prohibitive.
The advantage of the berkey, it does let minerals though. It has been used by missionaries in other countries to prevent the disease that is found there because of poor sanitation.
After the water is filtered, I will often add baking soda about 1 teaspoon per half gallon to help balance my bodies PH. I had in times past used a machine to make the alkaline water, but I found this too much work, and I got the same results by just adding baking soda.
But if you have pathagens in your water I would highly recommend Ozone treatment.
Filtration does not get everything, and there are pass thru filters ( very small organisms )
"Then they were examined under the Rife microscope where the filterable virus form of typhoid bacillus, emitting a blue spectrum colour, caused the plane of polarization to be deviated 4.8 degrees plus. When the opposite angle of refraction was obtained by means of adjusting the polarizing prisms to minus 4.8 degrees and the cultures of viruses were illuminated by the monochromatic beams coordinated with the chemical con*stituents of the typhoid bacillus, small, oval, actively motile, bright turquoise-blue bodies were observed at 5,000X magnification, in high contrast to the colorless and motionless debris of the medium. These tests were repeated 18 times to verify the results."
ROYAL RAYMOND RIFE & THE CANCER CURE THAT WORKED! by Barry Lynes
For this I suggest either building a strong immune system or using ozone after you have filtered.
Again distilled is the best I have found, but you need to get the minerals back to the water.
( I hope I don't get shot for answering this subject in renewable energy area, but I loved this subject
Mart
