Old 11-28-2011, 12:37 AM
Aaron's Avatar
Aaron Aaron is offline
Co-Founder & Moderator
current sensing resistor
Originally Posted by Mario View Post
you started adding loads on the neg. output line and then on the front side... and then jumped to other examples.
Mario,
My examples were identical each time.
I wasn't adding "loads" on the neg. The reason it is called a current
sensing resistor
and can be a 0.25 ohm resistor for example is because
it is only really there to be used for measuring what current is moving
pass there and is NOT acting as any significant load itself. Again, it is for
measurement and is not about being a load itself.
If you have a resistor there, you can measure what a solid state oscillator
or an SG is drawing from the input battery. If it is an SG, the wheel is
NOT the only work being done.
