Old 11-13-2011, 11:44 PM
MonsieurM's Avatar
MonsieurM MonsieurM is offline
Platinum Member
Send a message via MSN to MonsieurM
Originally Posted by MonsieurM View Post
alpha_and_beta quartz
both alpha quartz and dna are coaxial helices
------------Now apply the above infos to the following
RF coils, helical resonators and voltage magnification by coherent spatial modes
structured water :from The mechanysm of water structuring
For example sound in water medium would need to be at 72.36Hz to achieve the same wavelength as radiowaves at 13.56MHz.
It is found that coaxial helices with optimally mated symmetries can lock into spatial resonance configurations that maximize their interaction. The resonances are represented as vectors in a discrete three-dimensional space[
Luc MONTAGNIER DNA Teleportation
A Nobel Prize winning biologist has ignited controversy after publishing details of an experiment in which a fragment of DNA appeared to 'teleport' or imprint itself between test tubes.
According to a team headed by Luc Montagnier, previously known for his work on HIV and AIDS, two test tubes, one of which contained a tiny piece of bacterial DNA, the other pure water, were surrounded by a weak electromagnetic field of 7Hz.
Eighteen hours later, after DNA amplification using a polymerase chain reaction, as if by magic the DNA was detectable in the test tube containing pure water.
note: looks to me that a zone of activation was created then the dna transfer was accomplished
and also the weak electromagnetic field of 7Hz used is actually close to Schumann resonances:
let's not forget the use of quartz test tube (maybe )
The Schumann resonances (SR) are a set of spectrum peaks in the extremely low frequency (ELF) portion of the Earth's electromagnetic field spectrum. Schumann resonances are global electromagnetic resonances, excited by lightning discharges in the cavity formed by the Earth's surface and the ionosphere....
....as distinct peaks at extremely low frequencies (ELF) around 7.83, 14.3, 20.8, 27.3 and 33.8 Hz.
Signs and symbols rule the world, not words nor laws. -Confucius.
