Old 11-13-2011, 11:43 PM
MonsieurM's Avatar
MonsieurM MonsieurM is offline
Platinum Member
Send a message via MSN to MonsieurM
Rules of Harmonics
The mathematics of the grid can be called harmonic math, as the entire system is harmonic in nature. The rules to understanding this harmonic system are as follows:
1. Zeros to the left or right of the decimal point are insignificant.
2. The system is based on 6 and 10.
Looking at some examples for each of these rules will illustrate their significance.
Example: 144000 nautical miles/grid sec is the maximum speed of light at the equator. Examining 144000, we find the following:
144000 is harmonically equivalent to 144, 14.4, 1.44, and .000144.
144 x 1000 = 144000
14.4 x 10 = 144
1.44 x 10 = 14.4
.000144 x 10000 = 1.44
Example: Let's examine the coordinate 14.4 N, 144 W.
Both the latitude and longitude are harmonically
equal to the speed of light 144000.
14.4 N) 14.4 x 10000 = 144000
144 W) 144 x 1000 = 144000
Example: Let's examine the coordinate 86.4 S, 2.4 E.
Again both the latitude and longitude are
harmonically equal to the speed of light 144000.
86.4 S) 86.4/6 = 14.4, and 14.4 x 10000 = 144000
2.4 E) 2.4 x 6 = 14.4, and 14.4 x 10000 = 144000
These examples were chosen for their simplicity. Usually the analysis of a coordinate is not as straightforward.
------------- other example posted earlier: The Golden Tractate of Hermes Trismegistus applied to electromagnetism
Principle of correspondence
Originally Posted by MonsieurM View Post
and probably that is why Tesla used to weight his coils too, it is much easier than finding 5.914441183 feet
look what i found you too are related to Light speed
As the concentration of NaCl was increased further in the TIRFM assay the Rad51 filaments shortened more rapidly, with a measured rate of 21.12 ± 7.34 nm/s at 500 mM NaCl.More importantly, at this higher concentration of salt the DNA returned to near its original length with a final measured value of 5.91 ± 1.02 μm, indicating complete dissociation of Rad51.
side note: from this post:
Edgar Cayce often recommended animated ash and ultra-violet light therapy for persons suffering from cancer. The readings stated that the animated ash would increase the oxygen in the body and assist the immune system in fighting the cancer.
"All matter is crystalic in nature" -- W.Russell.
The qualities of a high-temperature superconductor — a compound in which electrons obey the spooky laws of quantum physics, and flow in perfect synchrony, without friction — appear linked to the fractal arrangements of seemingly random oxygen atoms....
...Those atoms weren’t thought to matter, especially not in relation to the behavior of individual electrons, which exist at a scale thousands of times smaller. The findings, published Aug. 12 in Nature, are a physics equivalent of discovering a link between two utterly separate dimensions.
Principle of correspondence:
Originally Posted by clueless View Post
That from a 2002 article. Unlike so many other promising breakthroughs this is one that has been widely implemented.
To further quote from the article: "The innovation, called Fractal Structure Circuit(TM) (FSC), uses fractalized conductor paths to replace the capacitors, inductors, and resistors in "RLC" circuits."
And another quote: ""Virtually every electronic device uses coils and capacitors to form RLC circuits. These discrete components are arranged by tried and true rules to get the circuit to perform as needed. What we've done is ask: can a fractal pattern, with its self-capacitance and self-inductance, be used to eliminate components and still get the equivalent RLC circuit? We've found that the answer is yes; and in most uses, especially at microwave frequencies, all components can be replaced by conductive fractal patterns or 3D structures."
And one more blurb from that article: " Looking at the Fractal Structured Circuit(TM) one sees, for example, a beautiful etched copper pattern replacing the usual traces connecting button or canned shaped capacitors and coils (or their SMT counterparts). "
Here is the link to that article.
Fractal Antenna Systems, Inc.
Apparently it is in wide use in cell phones, their antennas and some microwave circuits.
People are making homemade fractal HD antennas using coat hangers as one instance of using a common material.
I think this feature; fractuals should be used in some builds to take advantage of a wideband of frequencies and resonance. Maybe it will be useful in the Muller/Romerouk build.
For those that be interested google fractal circuits and fractal antennas.
I do not have the resources/space/knowledge to do any builds at the moment but I am curious enough to verify if a HD antenna can be made simply using fractals and common materials.
Any way something to consider.
-RG signing off
in other words:
Fractal Structure Circuit = R L C circuit (works both ways )
Let's not forget
fractal property of nature
Patterns of Visual Math - Fractals in Nature
Fractal in Human Body
Applications of Fractals - Human Body
