Old 11-12-2011, 06:50 PM
MonsieurM's Avatar
MonsieurM MonsieurM is offline
Platinum Member
Send a message via MSN to MonsieurM
The key in this regard [pardon the pun] is that Music is basically about ratios, frequencies (geometrical sine waves), and timing (a very mathematical kind of thingamagig). There is also a strong geometrical connection, in that, if one takes the unique 3-4-5 right triangle (with sides of 3, 4, and 5 equal units -- the only triangular shape utilizing a combination of single digit whole numbers which result in one angle of the triangle equaling 90 degrees -- however, larger numbers such as 5, 12, and 13 also work), and strings a continuous fine wire to each of the three points of the triangle, it is then possible to tune one of the sides to a particular note, and have the other two sides be in a tuned harmony. The three sides of the triangle form a series of tones that are equivalent to the first three strings of a tuned guitar. (One might also note that geometrically, one only has to tune one side of the triangle, while the guitar requires all three strings to be individually tuned!)
Signs and symbols rule the world, not words nor laws. -Confucius.
