firestorm details
To my understanding, the Firestorm need an enhanced ignition. I don't know if that means a higher voltage coil, capacitive discharge like CDI or what.
I think the plugs have no resistor in them.
The original prototypes were made by a jeweler.
Krupa look at used plugs and saw they liked to wear down into a half sphere shape so he thought "why not just make them like that to begin with." So he enlarged the head on the electrode stem and put wire loops on the ground side so equidistant spacing from the mushroom head annode. Therefore they can't misfire like other plugs. If the residual ionization in one area is too high for spark to jump, it simply jumps elsewhere...no misfire.
Krupa is one of the developers of the split fire plug so he didn't come out of nowhere.
I chatted with him a few times online and he is pretty quiet and doesn't say much.
Bosch tested 0% gap growth over their testing on these plugs...basically will never wear out...virtually no emissions from the tailpipe.
14.7:1 is always claimed to be the idea mixture...that is ONLY with a simple spark, but when using plasma bursts, you can release a lot more energy from a lot leaner mixture. 20:1, 40:1 and even just for show and not necessarily practical 100:1 was demonstrated.
I personally think these plugs or duplicates of the concept are what will make water powered engines practical as these plugs split water on contact. Even if people don't have high liters per minute water gas production, these plugs will let an engine run on it...in my opinion.
To think of it, I don't have the engineering skills, tools or experience of a lot of you here, but perhaps a non-fouler can be the base of one...insulate center annode from the non-fouler stick it through and weld on the loops...back side, some connector to stick plug wire too. I don't know if it would be as simple as this but maybe makes it easier than making from scratch?
