Thread: Bedini SG
  #332 (permalink)
Old 02-16-2008, 11:00 PM
Aaron's Avatar
Aaron Aaron is offline
Spiritual Entrepreneur
choke on trigger
This is great Sephiroth!
Chokes play a big part in Stan Meyer's WFC circuits. It is supposed to be one of the big keys that that nobody has mastered. It is part of the "voltage intensifier circuit" (VIC). As you pulse through the chokes, you're able to get higher and higher voltage out the end of the chokes, which the magnetic field of the chokes limit the current. Meyer used bifilar chokes... both wires wound around same coil. One choke on the front side of the cell and one on the back side of the cell with the cell between them in series...connected Tesla pancake coil style.
With the chokes, you're right that it isn't about the resistance. Even in Meyer's chokes, resistance is over 10k ohms, pretty high and Meyer says it isn't resistance that limits the current, it is the magnetic field in the chokes.
Anyway, are you able to post scope shots with and without the choke on the trigger?
How many turns do you estimate are on the choke? Gauge? Core material? Diameter? etc...? Picture of the coil?
Keep going!
