Originally Posted by Jetijs
I am using KOH as the electrolyte. Does the gas contain any KOH or does the KOH remain in the electrolyzer?
It should stay in the water. Just like the normal Brown's Gas Generators, you add the KOH once and when water level is down, you just keep adding water and the KOH re-dissolves in the water from the plates.
Without lighting the gas, put it on your body if you have any aches and pains. If you don't maybe you know someone that does...it is reported to eliminate pain, etc... Bubble the gas in good quality drinking water, then drink the water, supposed to feel better and more energized. Take the same water with the hho bubbled in it and water plants, you are supposed to see increased plant growth with it.
Try to melt a rock...should turn into a liquid puddle...when it hardens, should be very hard with hardness of 9...diamond is 10.
