Old 10-23-2011, 08:33 AM
soundiceuk's Avatar
soundiceuk soundiceuk is offline
Gold Member
Originally Posted by mbrownn View Post
First you have to extract the radiant from the environment, its like sitting in a swimming pool and trying to get the water to do something.
This is why the collector needs to be negatively charged.
This can be modified with a diode so that the energy is built up in the capacitor to a higher level before use.
Where would the diode go and what sort of specification capacitor/s and diode do you think would suit the circuit?
The small devices most of us have built with this patent produce tiny amounts of electricity, so small as to be mostly unpractical to use; however if one of these devices was placed close to something that is disturbing the aether the output would go up dramatically.
Is there a thread on any of these small devices? It would be interesting to know whether they were negatively charged, their surface area and elevation.
I know that the surface area of the collector and its height are very important.
An interesting notion is that the monolith inside a catalytic converter has a surface area of approx 500,000 square meters.
If the plate was replaced with a coil, we no longer have to be as close to the source or in direct line of sight but now we are moving onto another of Tesla's patents.
There is a lot of surface area on a coil, much more than a plate of the same size.
Which patent do you refer to?
