Thread: Earth Rods
Old 02-13-2008, 07:40 PM
Aaron's Avatar
Aaron Aaron is offline
Co-Founder & Moderator
antenna
Originally Posted by elias View Post
Hi,
I had experimented with charging capacitors before by using an antenna and an earth rod. So It may be possible to instead of drawing the aether only from the earth, draw it from the sky and the earth by a bridge rectifier. Isn't this reasonable?
Elias
I've used several antenna setups and did get benefit but I didn't do enough comparison to see what benefit came from where...antenna or ground rod. Either way, the effect seems to grow if left alone long enough...weeks to months. I'll bring some other things up soon.
If this particular setup is ground rod and diode to + on charging battery, try maybe antenna on the - of charging battery (same as + on input battery) if using SSG setup or not if using cap method. Try with no diodes, then try with diode pointing both directions.
